Fuji GFX- leaf shutter??
aztwang
Has there ever been any talk from Fuji about producing a leaf shutter lens for GFX? And would the GFX/GFXs be capable with only firmware updates?
It would be such a plus for the GFX system.
P. Chong
The GFX can already use the leaf shutter in the Hasselblad .HC lenses via Fuji’s adapter. Works brilliant. The HC lenses are made by Fuji anyway. So I am sure they are fully capable.
GeorgeBo
Is there a specific lens firmware requirement that the HC lenses have to have to work with the Fuji adapter?
robmac
Just note that when the GFX adjusts the aperture as requested via a command dial, it does it THEN, not automatically at the time of exposure (as does the X series with H lenses). It's stop-down metering, etc., but you can just program a back button for preview in manual focus to twitch preview on/off as desired when focusing and composing.
The H series lenses are strong performers on the GFX and the ability at the push of a button to go from leaf shutter with 1/800 sync or body shutter at 1/4000 max and (if able with your lights) use HSS is nice. Also means you can save activations of the leaf shutter when sync at 1/125 (say in studio) is fine.
so how to adjust the aperture when using an H lens on GFX?
