Does anybody in the community run this combo on location? I just migrated to using the MBP 16" and the battery of the MBP gets drained so fast its scary. Anybody has the same experience? Tested running activity monitor while the MBP was processing images and it spikes up in the 400 range in cpu. According to Apple 100 is already high. I did the test both in C1 12 and C1 20 - same result. On a shoot last night with the MPB running together with an external battery pack plugged in under light use with just C1 running, the MBP was empty in about 1 1/2 hour. Is C1 really optimized for Catalina?
I can't help with battery use while processing IQ4150 pictures (don't own one) but would like to give insight into performance and suggest where the power use actually happens. I just got my own 16 inch MPB, so I am also learning what it can do.
The 16 inch MBP has 8 processor cores so it can peak at 800%. Apple saying 100% is high is somewhat misleading. That peaks one core, but there are 7 cores left. You are seeing about half the processing capability being used. This is fine.
Then there is the word "spike". If you measure any modest activity on a short enough time interval it will consume 100% of computing during the short measurement. Sustained 100% activity is what burns power, not spikes. You are not seeing sustained activity.
But this is not the important area to look for power consumption. One big usage area will not even show up in the perf monitor.
The new MBP has a very powerful video card. Capture One uses that video card for accelerating picture processing. This is probably where the big power usage goes.
That device can really burn power when it is turned loose. You can tell this by feeling the case. It will get very warm and the computer fan will be loud. I don't doubt it could drain the battery in short time.
You can disable Capture One from using the video card to accelerate picture processing, but then it will take longer to complete. I imagine disabling acceleration would use battery power more wisely, but at what cost in time?
I would stay with the default acceleration feature and take along some of those power packs that can recharge a battery in the field. A power pack with USB-C connector would fit directly onto one of the four MBP USB-C ports.
Bottom line: if you don't use the video card for accelerating processing, the bigger battery in the new MBP will give improved life. But, turn on the video adapter power hog and no battery will give great life. That is just the nature of high power devices, they work best when connected directly to a power supply.
Apple gives you a choice of longer battery life or powerful processing but you can't expect both under field conditions.
