Shashin
Hard to answer: you might just have very weak willpower. Or the cat made you do it. (RU in a hostage situation?)When have I ever resisted posting pictures of Soup?
Or I'm still shocked that there is a photo forum that actually *wants* cat pictures.Hard to answer: you might just have very weak willpower. Or the cat made you do it. (RU in a hostage situation?)
Not any old cat! This cat. The Soupster!Or I'm still shocked that there is a photo forum that actually *wants* cat pictures.
The results speak for themselves! That looks really good.You might have missed an option that I mentioned in my earlier post to this thread. Here's a single image taken with an Arsat 30mm fisheye, tidied up a bit from when I first posted it.
Which adapter are you using?The Pentax 645 35mm, 75mm, and 150mm, and tilt/shift adapter were all assembled this morning, so I went out and totally failed in my attempts at capturing architecture and cityscapes. I'll have to practice. Results were inconsistent, even at f/11. But only at infinity. They were all great at close to medium distance.
However.
Once I got home, I chased the Soup around the apartment and got
The FA 35/3.5 It sure can focus close, yet it doesn't scream "wide angle" to me.
The A 75/2.8 in very bad light (look at his pupil dilation!)
And the A 150/3.5 Now he's tired of this whole business.
So they work fine on close subjects, but that's not really what I need shift for.
Matt
Edit: It looks like it was air currents. I shot with the XCD 28P and the edges didn't look much better. That's the problem with infinity. There's a lot of stuff between it and the camera.
The Fotodiox Pro TLT ROKR. I can focus past infinity with it - maybe too much past infinity. The lenses read about 10-40 meters when focused at infinity. But unless there are floating elements, I don't see how that could be responsible.Which adapter are you using?
I was wondering about that. I am looking at the Fotodiox Pro Shift adapter and the website says "focus to infinity and beyond" in the description. I didn't know if they were just throwing in a movie reference or if it actually went beyond. Do you find it has much of a practical downside or is it really not much of an issue?The Fotodiox Pro TLT ROKR. I can focus past infinity with it - maybe too much past infinity. The lenses read about 10-40 meters when focused at infinity. But unless there are floating elements, I don't see how that could be responsible.
I just did some careful testing at about 40 feet. My FA 35mm does have a bad corner, in that I can't get it sharp at f/8 or f/11 even unshifted, but the loose fit of the adapter also makes for some tilting of the lens. With the 35, that makes a noticeable difference in focus even at f/11, so even if there's field curvature, there's also field tilt. In other words, it's a mess.I was wondering about that. I am looking at the Fotodiox Pro Shift adapter and the website says "focus to infinity and beyond" in the description. I didn't know if they were just throwing in a movie reference or if it actually went beyond. Do you find it has much of a practical downside or is it really not much of an issue?
I really appreciate the advice and the pictures of Soup!
Thanks, Rob, I checked those topics, but the solutions proposed are "mirrorless centered" while I shoot with a IQ 140 on a Phase One DF ...Ah yes, 28mm... for someone like me using a GFX on digital view cameras, there is only one "OK" option (the PC Super-Angulon 28/2.8, in Leica skin or native Schneider-Kreuznach),
Are you using a tilt-shift adapter Matt? I have the Fotodiox Tilt ROKR, and have not used the Kipon version. But if I needed a new one, I'd buy the Kipon because it allows shift in both directions at the same time. There's a good post here (scroll down from the start): https://www.getdpi.com/forum/index....ilt-and-shift-adapters-for-gfx-and-x1d.63085/I just did some careful testing at about 40 feet. My FA 35mm does have a bad corner, in that I can't get it sharp at f/8 or f/11 even unshifted, but the loose fit of the adapter also makes for some tilting of the lens. With the 35, that makes a noticeable difference in focus even at f/11, so even if there's field curvature, there's also field tilt. In other words, it's a mess.
I have the manual focus 35mm on order, as @rdeloe's warnings about the FA's field curvature seem quite justified. But I should also exchange the adapter. Does anyone else make one? This seems well made, save for the fit on the X2D mount, but it wasn't cheap, so I'd prefer one that was well machined! The 75 and 150 are small, sharp, and light enough to be used unshifted, so I could get a much cheaper fixed adapter...
There are fewer shift adapters from the Hasselblad. I like Kipon better, but haven't seen one by them for the X2D. Never mind. Just found one.Are you using a tilt-shift adapter Matt? I have the Fotodiox Tilt ROKR, and have not used the Kipon version. But if I needed a new one, I'd buy the Kipon because it allows shift in both directions at the same time. There's a good post here (scroll down from the start): https://www.getdpi.com/forum/index....ilt-and-shift-adapters-for-gfx-and-x1d.63085/
The HD Pentax-D FA 35mm has the same issue. I could only shift it 10mm on a Fotodiox Tilt ROKR.Interesting discovery... The problem with the Fotodiox adapter and the Pentax 645 FA 35mm is that at the extreme 2mm of shift, the lens will not focus at infinity. The rear element hits something. Shift only 10mm, and infinity is (relatively) sharp. I now also have the heavier and better built Kipon adapter (which has a tripod foot). We'll see when the light is better.
That is the principal design weakness of this style. When I used one of these, it was better when I held the adapter in a lens collar. That reduced the amount of recomposition. The Kipon tilt shift adapters that allow shift in two separate directions at the same time solves this problem nicely.I have the the Fotodiox Tilt/Shift ROKR for the Mamiya 645 lenses, but it does not allow use of tilt and shift on the same axis to permit using it for rise/fall with tilt as one can do with the Canon TS-E 24 II.
Alas, the Kipon adapter I found only shifts in one direction at a time, but can orient the tilt independent of the shift.That is the principal design weakness of this style. When I used one of these, it was better when I held the adapter in a lens collar. That reduced the amount of recomposition. The Kipon tilt shift adapters that allow shift in two separate directions at the same time solves this problem nicely.
It makes a big difference if one uses a lens that requires minimal recomposition after tilt. Lenses with a focal length close to the flange distance of the system work best in that respect. This is why the Pentax 645 75 mm was pleasant to work with.
That's actually a big win. It's nice to be able to shift in both directions, but being able to do a rise or fall while tilting, or a shift while swinging, makes this adapter vastly more usable than the design that only allows shift with tilt, and rise with swing.Alas, the Kipon adapter I found only shifts in one direction at a time, but can orient the tilt independent of the shift.
